Instrument cluster fastening?
Old Dec 12, 2013 | 03:20 PM
earlyrover's Avatar
Default Instrument cluster fastening?
My main instrument cluster shroud, or whatever you call it, that sits on top of dash in front of driver, is a bit loose, on the right side, so that when the heater fan is on full blast, the cluster shroud makes noises as it pop up and down about 1/8" or something like that. There are no visible holes in the shroud, where screws would be found, etc., so does anyone know what holds this shroud down on to the dash itself? How do I tighten this sucker up?
Old Dec 12, 2013 | 03:29 PM
04duxlr's Avatar
There are 2 screws at the bottom of the shroud (it's called the nacelle in RAVE) behind the top cover on the steering column and then 2 clips in the back that slide into the dash. RAVE has a nice image of it under the Instrument section.
On mine, the screw holes had been snapped off the back of the shroud so I rebuilt them with a j-b weld type epoxy and then drilled new holes. Made it nice and quiet so now I can hear all of the other noises it makes.
Old Dec 12, 2013 | 03:32 PM
ZGPhoto's Avatar
Mine kind of just flops about where it wants to go. It's a free country.
Old Dec 12, 2013 | 06:29 PM
bballjames's Avatar
Haha
Mine had the same issue. I super glued a couple metal washers behind the holes for the screws just to reinforce it. (That's where it was cracking on mine). Has been nice and snug for 1+ year now.
Old Dec 12, 2013 | 08:34 PM
DiscoBeau's Avatar
Quick fix so its not annoying. Put the joke that they call tilt/steering down, take about 4 napkins in half and put them under the shroud and put tilt back up... done till you find some screws.
Old Dec 12, 2013 | 09:19 PM
Madlands's Avatar
The screw holes and the plastic tabs on the back of my shroud are all broken.
I use 2 1/4inch sheet rock screw in each hole. The screw heads are big enough that they hold perfect, you wouldn't know the tabs on the back are broke! Plus the steering wheel covers them up so you'd never know.
Old Dec 13, 2013 | 01:50 PM
earlyrover's Avatar
Thanks so much, guys. I should have known it would be the plastic that was the guilty party! Had a Classic 91 Range Rover with middle of plastic dash warped upward; my latest 2004 Discovery with almost the same ailment, so I glued it down with firearms specification epoxy, the best epoxy in the world, so looks like I now have to reinforce holes; maybe cracking of plastic, to also get instrument cluster to stay down and be quite about it! Someone should have sold a lot of quality epoxy to Rover when they were manufacturing these Discoveries. When, in auto. manufacturing, will the extensive use of plastics cease, or at least slow down? I fear, that if you have an auto fire, the black smoke from the burning plastic will kill you before you can get the seat belt off and door open!
Old Sep 13, 2022 | 08:29 PM
Wannabe Mechanic's Avatar
Hey mate I have the exact same issue. How did you shape the epoxy to fit nicely between the shroud and the instrument cluster? Or does it not matter if its the same shape as the original screw mounts?
Hopefully you see this as I just noticed how old this thread is😂
Cheers
Old Sep 13, 2022 | 09:49 PM
04disco2va's Avatar
Yes I used sheet rock screws as well. Work perfectly and are black so looks like it came that way.
Old Sep 14, 2022 | 08:59 AM
XRAD's Avatar
there are also two plastic locking tabs on the inside of shroud, mating to dash top. these are usually broken too. Easy to 3D print up a new set and using Devcon platic welder, repair the shroud....
https://www.thingiverse.com/thing:3436728
riko suave
Mar 18, 2009 04:34 PM
Panic
Feb 23, 2009 01:41 PM
CandiMan
Oct 30, 2008 01:39 AM
coldfrez
Oct 1, 2007 09:49 AM
Greg
Aug 8, 2007 04:47 AM
