Instrument panel bulb replacement
Old 03-16-2015, 01:02 PM
Kordian's Avatar
4wd High
Which green bulbs? If I am not mistaken there are 3 "big" bulbs and 2 small available for repacement from the back, not more. The 3 big ones are for lighting the panel in general, one of the small ones is for main road light (blue I guess).
And to be honest I do not find the main light of the panel hideous. It is perfect for driving in the night as new leds are by far brighter, which makes my eyes sore after half an hour of night driving.
Old 03-16-2015, 01:10 PM
bballjames's Avatar
Originally Posted by Kordian
Well, actually I did not look into the inside of the panel. Just disassembled it and removed the back milky cover. Found nothing but electronics there and many screws. I am not sure if this is enough to unscrew them to get to the leds and was affraid to do more damage.
But if somebody confirms how to get to the inside of the panel without damaging anything, I will continue with my quest :-)
Can you post a picture of what you are looking at? You should have it dissembled enough to tell if the LEDs are still there or not. I guess even if they are there, they aren't working...
Honestly I would just replace the cluster. Get a good used one, pay a local indie rover shop to resynch it and be done. Probably will cost you $75 for everything, but you'll have everything working as it should.
Old 03-16-2015, 01:23 PM
Kordian's Avatar
4wd High
Actually I ordered a new used instrument panel.
Do I need to resync it? What does it mean and how to perform it?
Old 03-16-2015, 03:03 PM
bballjames's Avatar
You need to synch it with the ECM/BCM. You can do it yourself if you have a hawkeye, nanocom, or similar. If you don't have one of those, just find a local indie land rover shop and they should only charge like $25 to synch it depending on their labor rate. Takes like 5 minutes, but most shops have a half hour minimum.
You might be able to find another member close to you that has something that can be used to resynch it.
Old 03-18-2015, 06:06 AM
Kordian's Avatar
4wd High
I have access to the following soft:
Texa Nano
Delfi DS150
Can I resync the panel using any of these?
Can anybody instruct me?
Thanks in advance for the help!
Street Wolf
01-20-2012 08:04 AM
Prometheus
01-18-2011 07:37 AM
Classklown90
08-21-2010 07:24 PM
SC Rovergirl
Audio/Visual Electronics
05-12-2010 07:00 AM
rphotographer
11-20-2008 08:20 PM
Quick Reply: Instrument panel bulb replacement
