instrument panel is out...
Old Jul 12, 2016 | 03:57 PM
Lost's Avatar
Default instrument panel is out...
The gas gauge works, the SRS light goes on/off upon start, and when I turn on my headlights the panel lights up.
all accessories work
I have checked all the fuses with a continuity tester...every single one tested good.
Made sure all fuses were seated properly. replaced one, that looked corroded, but still tested okay.
what is everything else that I should check before replacing the instrument panel?
Thanks
Old Jul 12, 2016 | 04:58 PM
disc oh no's Avatar
None of your gauges are doing anything?
Old Jul 12, 2016 | 08:50 PM
Lost's Avatar
just the gas gauge, it goes all the way to full... which is not accurate. When I pull the fuse and turn it over the gas gauge does not work as well.
Old Jul 12, 2016 | 09:02 PM
disc oh no's Avatar
I've never really had any trouble with mine. Aside from bulbs, but I don't really consider that a "problem". More of just a minor inconvenience.
Have you done other work to anything else in the truck? Or did this start on its own?
The reason I ask, I just worked on a car that had a problem with the fuel gauge after replacing the SAI solenoid. I don't know what the actual problem was with it. It was pulling the 5 volt reference circuit down to 2.5 volts and causing a bunch of trouble. The gas gauge would go over full and then drop to empty.
Have you tried scanning the truck for codes?
Desert Roadrunner
Dec 31, 2010 02:01 AM
afox04
Apr 28, 2008 10:15 AM
jonnymcd
Mar 24, 2007 01:07 AM
litterlout
Aug 27, 2006 11:16 AM
James Vee
Feb 1, 2006 10:34 AM
