Instrument Panel and Tail Light Problems
Old Jun 12, 2005 | 11:23 AM
James Vee's Avatar
Default Instrument Panel and Tail Light Problems
For some reason, I've had problems with my intrument panel not lighting up and my tail lights not working. Problem is that it is not just a fuse. They are come and go. Any ideas or suggestions?
Old Jan 30, 2006 | 02:16 PM
scottwork's Avatar
Default RE: Instrument Panel and Tail Light Problems
I have the same problem on my 1998 Discovery. Did you find out what was causing this?
Thanks.
Old Jan 30, 2006 | 06:54 PM
esaycho's Avatar
I have had the same problem with the Instrument Panel not lighting up in a different car, it was cause of the dimmer switch, if i would just slide it down then back up it would work again.
Old Jan 31, 2006 | 09:17 AM
Lighting90's Avatar
I would suggest checking all your earth connections, this is the most common cause of electrical faults, esp as the vehicle gets older, some of the conenctions become very green with age.
Old Feb 1, 2006 | 10:34 AM
discoverylad's Avatar
4th Gear
had a problem that the headlights didn't come on, side lights, rear lights all cam on but the main front lights didn't, was found to be the switch, hope this helps
Rover505
Mar 14, 2024 11:38 AM
Motorhead1
Dec 16, 2014 09:40 AM
elpapisf
Apr 9, 2012 09:52 PM
yukonridin23
Oct 26, 2009 11:14 PM
jonnymcd
Mar 24, 2007 01:07 AM
