Intake manifold
Old Oct 19, 2008 | 04:28 PM
old gold's Avatar
Default Intake manifold
I thought I had just completed a head gasket replacement on a 1998 Disco but depression has set in.
I drained the coolant completely then filled with water and radiator flush.
I turned it over to check for leaks and lo and behold I have one injector leaking at the rail (easy fix) but I also see a very small water leak under the intake manifold.
Just below the thermostat housing there is a plug.
Just below that plug is where the leak is. (It's not the plug) It is dripping onto the lifter cover. I stuffed a rag to the right side of the leak assuming it
was coming from the gasket between the intake and drivers side head.
This did not stop the leak.
I assume I will need to yank the intake back out and figure out what I screwed up.
Any thoughts or suggestions where I might have gone wrong?
Old Oct 19, 2008 | 05:25 PM
Default RE: Intake manifold
Is everything tourqed properly?
I have heard but cannot conferm nor deny that the intake gasket has a front and back to it, so if it is on in the wrong direction it may leak. But like I said I do not know for a fact, maybe somebody elsew who does know can answer that one.
Old Oct 19, 2008 | 05:40 PM
As Spike has already asked, are you sure you got it torqued right.
By the way, you should be calling in a valley pan gasket, the intake manifold gasket is under the trumpit and has 8 matching air tube holes in it, did you replace it?
Old Oct 19, 2008 | 06:56 PM
old gold's Avatar
Mike, your right I should call it the valley pan gasket.
I assume what you call the trumpit refers to the ram housing?
What I found when I originally disassembled the engine was there was not gasket between the ram housing and the intake.
When I assembled I just used RTV (Rave says use Hylomar no gasket) anyway the leak is not at that joint but under the intake manifold and dripping down onto the valley gasket.
I got a head gasket kit from Atlantic British w/new head bolts and put the valley gasket in the correct orientation (it was marked front)
I was pretty careful to torque things properly per the rave cd.
Is there a plug on the bottom of the intake manifold that I may have missed?
Old Oct 20, 2008 | 10:28 PM
tacomatech's Avatar
I had a Disco I in the other day with a leak that looked like it was coming from the same spot. Upon further inspection, I found that it was coming from the upper radiator hose, running down the front and dripping in the same location you described. I tightened the clamp and the leak was gone. Double check that just to rule it out.
Old Oct 21, 2008 | 10:26 PM
old gold's Avatar
Thanks for the tip. I have already yanked out the intake manifold and upon further inspection found I had pinched the edge of the thermostat. This was keeping the thermostat housing from properly squeezing the gasket..........loooosssseerrr..........I know... I could have fixed it without pulling the intake but I think of it as practice!
Now for a 2nd new valley pan gasket and end seals along with a full o-ring set for the injectors
167k miles....those o-rings don't owe me anything.
jsyonker
Nov 12, 2012 09:15 PM
brw1982
Jul 21, 2008 11:42 AM
bal51365
Oct 10, 2007 09:36 AM
sealluke
Dec 17, 2006 11:58 AM
jbriggs
Jul 14, 2006 01:07 AM
