Integrated killswitch
Old Oct 29, 2019 | 09:21 PM
Jacobp's Avatar
Default Integrated killswitch
I made this killswitch with a engine control relay and routed it to an in dash button that I already had a few of. Id like to know what you guys think
These are female spade connectors, they fit perfectly
Then i tapped into the original place of the relay with the fla flat male spade connectors.
The bottom left is the kill switch, the car only runs when the button is pressed down. I changed the face from an emergency light switch like above with a blank so it wouldn't stick out
Old Oct 30, 2019 | 04:13 AM
JUKE179r's Avatar
Yep. That's one way of doing it.
I used the cigarette lighter as the kill switch in my '67 Jaguar 420. I wired the cig lighter as the ground side of the fuel pump and it had to be pressed in to start the Jag.
huggi
Apr 8, 2019 11:05 PM
ROB99DISCOSD
Jan 2, 2018 06:25 PM
peterh
Mar 16, 2017 07:51 PM
Crpecker
Apr 2, 2010 03:48 PM
