intense leak (spray) of transmission fluid from D2
Old Dec 10, 2018 | 10:09 PM
  #21
RubyRoverD2's Avatar
Talking think i found it
Originally Posted by mollusc
i don't recall how that hose connects to the water pump cover. if it's a standard clamp on a hose over a spigot, try examining the hose for splits or checking to see if the clamp is loose. sometimes doing something as simple as cutting off the degraded end of the hose and re-clamping it will fix the problem. if that does fix it, it confirms that the leak is not from the water pump gasket and at that point i would recommend replacing the hose because it may have deteriorated to the point where it could burst or split again in another place.
i went ahead and went and replaced the hose and the thermostat, my old hose had 2 small cracks and on decent size hole in the exact place the coolant sprayed out just i couldnt see it, i flushed my radiator and water pump, going to put coolant in it tomorrow, i will let you know if it still leaks but all looks good
Old Dec 10, 2018 | 10:33 PM
  #22
Dave03S's Avatar
What thermostat? They are not all the same. At this point you need to have the specific 180 degree specified above. No napa, no Mortorad.
Old Dec 11, 2018 | 09:41 AM
  #23
Smile
i got it from oreilly it was $37 and the description says its a 180 degree, i bought the only one they had with a 180 in the info, the rest where cheap $15 ones, both my hose and thermostat have a 2 year warranty
Old Dec 11, 2018 | 09:48 AM
  #24
Dave03S's Avatar
The O'Reilly is probably a reboxed Motorad... look for markings on it. Motorad thermostats have had a low level of quality assurance over the last few years. Many of them not being actual 180's in the 180 box. You can use it until you get the proper one or you can get the proper one now and not do the job again later. One of the units linked above will do the job right the first time.
While flushing be sure to run it with water in system and run the heat for a while, that will get the Dex out of your heater core.
Search on here for proper bleed procedure as well. An air pocket can cause you to overheat.
Good luck, hopefully it is only that hose.
Old Dec 11, 2018 | 11:56 AM
  #25
mollusc's Avatar
the heater core is open regardless of whether the heater is on or not. running the engine with the heater going doesn't do anything.
Old Dec 11, 2018 | 01:29 PM
  #26
Talking sounds good,
alright, ill keep it for now and ill replace it with a better thermostat in the summer when it isnt as cold!, its made by murray, only markings on it along with a part #
jpluncford21
Jan 11, 2016 09:16 AM
me 2
Apr 3, 2013 06:53 AM
1998DiscoverySE
Jul 20, 2012 08:02 PM
MADBALL
Jun 27, 2009 07:28 PM
jkid
Nov 16, 2007 08:44 AM
