Interesting finding with one of my injectors
Old Jan 19, 2014 | 07:32 PM
Club Cheetah's Avatar
Default Interesting finding with one of my injectors
Hi guys,
I'm in the middle of a injector seal, valve cover replacement, and a intake manifold gasket replacement after I found a vacuum leak. As the tear down began everything has been going great. The RAVE is one hell of a resource.
I am having some interesting findings with soot on some injectors but not on others. Also one of the injectors was missing that "shield" type thing next to the seal on the spray end. Could these be a problem and if so what are my options?
Mike
Old Jan 20, 2014 | 09:15 AM
04duxlr's Avatar
How many miles on your truck? You will have carbon built up on the ends of the injectors just like everywhere else inside the intake. It's the buildup inside the injectors that is the concern. That's hard to determine without testing them which requires special equipment. You should just clean them up and put them back in. If you get the vacuum leak fixed and it runs great you're all set.
Regarding the shield type thing, I believe you are referring to the o-ring retainer. That's pretty important. Do you think it may have dropped off when you pulled the injector? You should try and find that in the intake. If you can't then I think you need a new injector anyway.
Old Jan 20, 2014 | 03:04 PM
I found it in pieces on top of the manifold. I went ahead and noted which one in case of a misfire. Buttoned everything back up and took it for a spin. The issue I had with the brakes was immediately noticeable, as well as a smooth idle and no light!!!
Loks like a vacuum leak was the cause for my banks running lean.
Old Jan 20, 2014 | 05:17 PM
04duxlr's Avatar
Good to hear you got your vacuum leak fixed. I'm not sure how the injector fits into the manifold, but hopefully the o-ring is captured in the machined bore and can't come off.
Old Oct 27, 2016 | 10:04 PM
The_OGCJR's Avatar
Bumping this old thread because I have the same shield missing on one injector. It was not there on one injector. The machined bore on the intake is a really snug fit. I just don't see how the o ring could come off and go into the engine. Anyone disagree?
Old Oct 27, 2016 | 10:58 PM
abran's Avatar
Agreed. My first couple head gasket jobs I broke a random retainer or two and gott all **** and pulled them off of other injectors.
Then I was at veteran techs house and he was slamming them in without the retainers. Told me that is SOP and no problems.
MarkSF
Feb 1, 2014 01:10 PM
luxury1
Nov 30, 2008 12:42 PM
redbaron586
Nov 23, 2008 05:42 PM
S4poor
Jan 4, 2008 11:48 AM
Trader4Less
Feb 22, 2005 03:09 PM
