Interior Lighting help
Old Jan 20, 2007 | 11:29 PM
disco03hse's Avatar
Default Interior Lighting help
Hello Everyone...
I have a 2003 Discovery and my climate control buttons have stopped lighting up. The backlight display lights up green with the temperature settings but the buttons no longer light up.
Can anyone tell me the troubleshooting methodology they would follow step by step in troubleshooting this problem?
Thanks all...
Old Jan 21, 2007 | 12:58 AM
disco03hse's Avatar
Default RE: Interior Lighting help
hello all... I'm posting to my post because I forgot to add "other" things that I need help with.
1. Cruise control. > everytime I set it at speed 70mph on the freeway it is not smooth. ie: it feels like the gas is applied then let off and drops below the 70mph setting then speeds back up to stay at 70. Ive had lots of cars and this is the only one I've had that does this. Question. Is this normal? If not what could be causing this?
2. Windshield wipers. > takes about 10 to 15 seconds to engage once I turn it on (at any setting)
Any help is greatly appreciated.
Ken
[align=left] [/align]
Old Jan 21, 2007 | 03:58 AM
johnnybob06's Avatar
My cruise control does the same thing!.. so maybe its just a thing that LR's do???
John-Robert
Old Jan 21, 2007 | 11:15 AM
ORIGINAL: disco03hse
Ken
I believe the lights can be replaced for the climate control.
Your cruise control is vaccum operated and when you get a leak it will act up or not engage. Might want to check all the vaccum lines for the cruise including the one that run thru the fire wall to a switch at your brake pedal.
As for the wipers, does this happen on the rear wipers also? If not it sounds like you may have a wiper motor starting to fail.
Mike
Old Jan 23, 2007 | 11:38 AM
disco03hse's Avatar
Thanks...
Looks like I'm going to need a good repair / maintenance manual for my Disco... can you recommend one?
Old Jan 23, 2007 | 11:47 AM
Go to E-bay and buy a Rave cd that will contain the manual, usually costs about $10
Mike
usnavylt
LR4
May 1, 2015 03:40 AM
brandino
LR4
20
Aug 2, 2013 07:09 PM
RROJ
Jan 19, 2011 09:28 PM
nick731
Jul 29, 2009 10:53 PM
S4poor
Nov 14, 2007 10:21 AM
