Interior lights, radio and clock no worky
Old Jul 20, 2014 | 07:28 PM
steb4680's Avatar
I put the original bulbs in and nothing. Is there a sequence or code that can be read?
Old Jun 30, 2019 | 10:48 AM
markdeg's Avatar
Sry but i have the exact same issue... Did you ever come to the bottom of this please?
Old Jan 3, 2020 | 08:01 PM
Brandon318's Avatar
Just had this issue too. I plugged in the nanocom, quick spark, and now all interior lights, radio and clock are dead. All else works great.
Old Jan 4, 2020 | 10:25 AM
Brandon318's Avatar
For the future searcher, the solution for me was replacing fuse 20 (15A).
Old Jan 5, 2020 | 07:14 AM
greisinb's Avatar
The fuse chart in the interior isn’t very helpful for a couple of those fuses, including number 20. Here is a link for a quick chart which explains them a little better. A quick look here might save a lot of headache for a future searcher!
https://fusesdiagram.com/land-rover/...scovery-2.html
Old Aug 26, 2020 | 12:33 PM
za105's Avatar
Just wanted to add, Fuse 20 in the passenger compartment on driver’s side was the solution for me, so thanks for that!
Backstory: Was rewiring my aftermarket stereo unit and neglected to disconnect my battery at first, causing a small spark when the yellow wire touched metal. I promptly disconnected the battery and from then on worked with it disconnected, but after resoldering all my old bad wires and firing the vehicle up, I noticed the clock was off and the stereo wouldn’t come on. Wondered what I had rewired wrong, and didn’t even think about that first spark causing a blown fuse, but after coming here and seeing this, I checked and sure enough, that was it! Everything works great now!
Old Feb 14, 2022 | 11:01 PM
sdtimb's Avatar
Thank you so much for posting the resolution! I just finished installing a Ham radio and had the same issue. It was getting late and I'd planned on troubleshooting in the morning. Thanks to this post I won't have to stress about it all night.
machinetech
Nov 28, 2013 03:29 PM
machinetech
May 21, 2013 12:32 AM
MarvelVT
Feb 6, 2010 07:06 AM
cassie11
Jun 23, 2006 10:26 AM
JRdisco1
Jan 4, 2006 11:31 PM
