Interior maintenance
Old Jul 19, 2017 | 06:49 PM
Tomzsix's Avatar
Default Interior maintenance
I read mostly, how to prevent engine failure, service on suspension, and so forth. But I do not see much on keeping the seats and carpet in top shape. Mequiars seems to be top notch. Has anybody used any other products?? How about "new car spray"?? Does that really work??
Old Jul 19, 2017 | 07:41 PM
CollieRover's Avatar
youtube is a good resource. Steam is good for a deep clean and really gentle degreaser like dawn detergent.
I like to use Lexol on an damp sponge, both the cleaner and conditioner for the seats.
aside from that nothing special.
Old Jul 20, 2017 | 01:27 PM
batard's Avatar
On this topic, I've been thinking for years about getting the driver's seat reupholstered—it's pretty tatty and no amount of cleaning is going to help. The fabric itself is stretched and worn. A company called Exmoor used to make kits, but I don't think they're available anymore. You could probably get them done custom, but I'd bet that'd cost a good chunk of change.
Old Aug 12, 2017 | 04:43 PM
LandGrover's Avatar
How do I get more air flow out of my fan in my 04 Disco? My ac is on high but seems weak when air is blowing. The temp is fine just the flow of air. I understand there is no cabin filter.
Old Aug 12, 2017 | 05:21 PM
Davis31052's Avatar
Just an idea about fixing the seat. A lot of times, the drivers is the only seat that needs work. I have a local upholsterer who will do patch work.
I go to the auto salvage yard and find the same color material on the back seat and cut off that cover, making sure I get enough material to replace the bad section.
I disassemble the seat and take only the part needing repair. They stitch in the repair for $60-$80 bucks.
Old Aug 12, 2017 | 05:42 PM
Dave03S's Avatar
That's what I did, only my upholstery guy had a match so I just bought a yard for like $10. The whole job was just under $300 with me taking the seat in and leaving it with them. They also added new bolster foam as the left side was worn down. Like new now.
It's also a good time to fix your seat heater if it doesn't work!
Old Aug 12, 2017 | 07:13 PM
For cleaning I do Lexol cleaner for normal cleanings. For deeper cleans warm water with dawn detergent and a soft bristled electric tooth brush.
For conditioning I will use the Lexol conditioner for normal cleans than a couple times a year I will use Leather Honey.
Old Aug 13, 2017 | 05:26 AM
OffroadFrance's Avatar
Excellent post and idea, we all talk about engines, brakes, axles and gearboxes and never address the interior of our trucks when they are nearly as important for travelling comfort.
usnavylt
LR4
May 1, 2015 03:40 AM
Jokeman
Jan 22, 2007 02:54 PM
marcolanza
Mar 10, 2006 03:58 PM
Shay108258
Aug 5, 2005 04:05 PM
