Intermitent trouble tuirning my key in ignition
This has happened twice in the past week or so. I get in the car and insert the key that I have always used into the ignition but it won't turn to start the car. Pull it out and insert it several times and it is as if I am using a totally incorrect key. Meanwhile the car is over 100 degrees from being in the Texas sunshine so it would be nice to be able to get it going! Utter a few choice words and it finally turns and starts. ![Confused](https://landroverforums.com/forum/images/smilies/muBAORM.png)
I have a spare so I am going to switch off to that for a test and I was thinking of putting a bit of graphite made for locks into the keyhole in case I have some pins sticking. The key is straight and does not seem overly brassed from wear.
Just another day in Land Rover world!
![Roll Eyes](https://landroverforums.com/forum/images/smilies/Yrp3aj7.png)
I get that very rarely, 1-2x a year but its a pain in the ***. I've had it happen in cold, mild and hot temps so I'm not sure. My usual method to correct it now is to give the shifter a good ring or two to away from then back towards Park, then the usual jiggle the wheel and key at the same time. That encorperates a few problems all in one swift move lol. I also lock the car with the keyfob, then unlock again and try again.
![EEK!](https://landroverforums.com/forum/images/smilies/bmHv6Xb.png)
Rovin4life
07-22-2011 03:46 PM
