Intermittent brake light on instrument cluster
Old Mar 29, 2017 | 12:43 AM
abran's Avatar
Originally Posted by Luckyjayb
i know when I did the top end rebuild, I put them all to a wire wheel and even coated them in oil. Thinking about removing them and having them powder coated also
i couldn't resist. Sorry.
Old Mar 29, 2017 | 07:40 AM
Luckyjayb's Avatar
I know man. It drives me
nuts when I see them
too. I've been thinking about removing them then clear coating them
Old Apr 21, 2017 | 11:36 PM
Luckyjayb's Avatar
Default Update
Well I got the master cylinder rebuild kit and replaced it all and bled it properly and brakes are working fine and fluid isn't leaking at all. Now that issue is resolved, I still get the intermittent brake like on the dash that will flash on and off quickly. I'd say maybe 3-4 times in a 100 mile drive. I'm starting to think the sensor/cap is bad. Any thoughts
Old Apr 22, 2017 | 08:24 AM
Best4x4's Avatar
I ordered those Kingsborne Spark Plug protectors as well, but was shocked how long they were so I didn't use them. However they work GREAT for my 5/16 coolant hose running from the intake manifold to the coolant reservoir!!! I always bypass that horrible Throttle Body Heater Plate on all my Bosch engines and the 5/16 coolant hose runs across behind the alternator then over to the coolant reservoir. I was worried about it cracking due to the heat from the exhaust manifold, but those Kingsborne boots are perfect for that. I just used one and slid it down to where the most heat will be. Looks OEM and now my Bypass Mod is 100% complete.
Old Apr 22, 2017 | 02:58 PM
PalmettoDisco's Avatar
Yeah, it being since the rebuild, probably the float going bad. You can try a junkyard pull, or new one, if not ridiculously high priced.
Old Apr 22, 2017 | 07:46 PM
tcr6v1's Avatar
I had this same issue... swapped caps with my parts truck and that didn't fix it so I cut and soldered a new plug on it and that solved the issues.
riko suave
Mar 18, 2009 04:34 PM
CandiMan
Oct 30, 2008 01:39 AM
coldfrez
Oct 1, 2007 09:49 AM
Greg
Aug 8, 2007 04:47 AM
