Internal Frame Cleaning and Rust Prevention
Old Mar 13, 2025 | 09:11 PM
Casualfriday's Avatar
Default Internal Frame Cleaning and Rust Prevention
My frame is in decent shape but I’m trying to make it last for another 20 years. Spent last weekend wire brushing, sanding and coating the exterior of the frame. Now I’m trying to get the interior of the frame cleaned and protected as much as possible.
My thought plan currently is to use a powder washing to get out any dirt and small rust flakes. Then use a drain auger with a drill attachment to break up as much of the larger flakes. After flushing out again with the power washer, I’m thinking about coating the inside with Eastman’s Internal Frame Coating.
Any suggestions are welcome.
Also, has anyone drilled holes in the frame or enlarged the factory ones? It would be alot more effective to flush out with a sewer jetter attachment to my power washer but I don’t think the factory holes in the frame will be large enough to fit.
Thanks
Old Mar 14, 2025 | 11:38 AM
Richard Gallant's Avatar
Pull the rear bumper, the frame is open at the back you might be able to snake a flexible hose down that way
Old Mar 14, 2025 | 01:32 PM
Thank you!!! Kinda hidden up there. I think I can squeeze the sewer jetter hose in there and run it down the frame without even removing the bumper.
although now I’m debating even washing it out as I’m afraid putting more water down there will just exacerbate any current rust. Might just spray some fluid film in there and call it a day.
Old Mar 14, 2025 | 01:43 PM
Extinct's Avatar
I did cut slots in the frame between front and rear axles on one to allow larger pieces to be flushed out. Suggest watching videos on rust protection products. I settled on fluid film on top of the Eastwood frame coating. If you have ever worked on a truck that has been in the north the frame under the engine is coated in oil and looks pristine and the rear end is super rusty. Nothing like a good coating of oil to totally prevent any rust.
Old Mar 14, 2025 | 03:14 PM
Thanks! I did do a bunch of research for the exterior of the frame on how to prep it and products to use. I went with the Mastercoat Essential Paint Kit which is two coats of their permanent rust sealer primer and a top coat of their ag111 anti graffiti top coat. It’s a real solid kit and I won’t have to redo it every year (hopefully never again).
However I’m having a tough time finding research on how to prep and what the best product to use is on the interior of a frame that has rust in it already. Some people say to flush it out with water first and clean it as best you can, others say that makes the rust worse as it adds more h2o and just to coat on top of the existing rust.
Probably need to just resign myself to making it better and not dumping a bunch of money into trying to make it perfect
Old Mar 14, 2025 | 06:32 PM
Extinct's Avatar
I would wash and then paint with rustoleum rust converter before coating.
PJWinnie
Nov 10, 2024 06:58 PM
dandswicks20
Dec 5, 2023 08:58 PM
escott16
Apr 2, 2020 12:52 PM
ge234
Mar 30, 2019 12:39 AM
dieselvaden
Mar 4, 2016 11:28 PM
