Its developed a thirst for coolant. Again.
Old May 23, 2015 | 06:58 PM
  #21
disc oh no's Avatar
Originally Posted by zeroone
It wasn't actually a headgasket failure. I bought a full top end gasket kit due to extreme coolant loss. Turned out the lower intake manifold gaskets where completely gone. I replaced the HG purely because I had the engine torn down that far. When I did the repair I went into it thinking I lost the HGs. It has yet to overheat. I'd love for it to be as simple as a headgasket failure. I really would.
I see, did you check the heads for warpage while they were out? If not, there may have been a little bit and it didn't sit down on the gasket correctly.
That small of an amount of coolant over a couple weeks is not a huge amount. (if you drive it more than a few miles a week, that is!)
Old May 23, 2015 | 11:39 PM
  #22
zeroone's Avatar
The heads where checked, and well withing spec. I did skip milling and a valve job against my own better judgement. If this is what I get for cheaping out, then so be it. I will gladly fix it again.
Old May 24, 2015 | 07:21 AM
  #23
disc oh no's Avatar
You know, if you're going to get someone there with a camera, you may be able to verify coolant in the cylinder by letting it sit for a long time and then checking it. I remember mine would misfire in the morning on first start up and then it would go away for the rest of the day. The coolant would kind of build up in there over night and make it misfire.
Were the heads warped at all? I'm just curious because if not you may want to check the block surface while you have the heads off. If there's no warpage there, it may be worth getting at least that head pressure tested and make sure it's doesn't have a leak in there somewhere.
Good Luck, I hope everything works out for you.
Old May 24, 2015 | 08:21 AM
  #24
zeroone's Avatar
Will do. Thanks.
abran
Jun 30, 2014 12:43 PM
kenjisnocon
Jun 16, 2009 06:28 PM
llPANCHOll
Feb 26, 2009 07:32 AM
domyo
Aug 27, 2008 06:26 PM
