It's those ... rear door locks!
Old Jun 4, 2009 | 12:51 AM
Disco Fuego's Avatar
Question It's those ... rear door locks!
Issue: Rear door locks do not lock or unlock with the remote. The only thing they do is go into superlock from locked or unlocked position. Then after I "unlock" with the remote I can open the door again from the inside.
I read some people have luck by spraying the lock, tried it, didn't do a thing. Do you think the actuators are bad? Or is that not the case because the superlock does activate and deactivate with the remote?
Cheers!
Old Jun 4, 2009 | 05:25 PM
The superlock is seperate from the door locks.
Does it only open from the inside?
Old Jun 4, 2009 | 05:45 PM
Yes and only if the superlock is not engaged (obviously...)
The don't lock either, unless I hit it twice in a row which engages superlock.
Old Jun 4, 2009 | 06:12 PM
Well if the door only open from the inside then it could be a broken door spring, there is a spring that attaches to the door latch and that is what open the door, at least on a DI anyway.
Its alittle more complicated then that but that spring gets weak/breaks.
If the locks wont move on their own but you can move them by hand than I think its time for new actuators.
www.roverlandparts.com
Old Jun 4, 2009 | 07:15 PM
Sorry, I misunderstood your question. The door only unlocks from the inside, but opens up from inside a well as outside once unlocked.
As far as moving the locks: I can lock it by pushing down the button, but I can not pull it up.
Old Jun 4, 2009 | 07:31 PM
Sounds like it is your lock actuators.
Old Jun 4, 2009 | 07:53 PM
I was afraid of that... Oh well, at least it keeps me busy!
nhra6306
Nov 13, 2020 11:01 PM
PFS
Dec 26, 2011 07:32 PM
scootch61
Oct 23, 2010 05:28 PM
clockmaker21
Jan 7, 2010 09:20 AM
NWRover750
May 24, 2008 01:08 PM
