I've got a new noise
Old Jan 26, 2015 | 01:24 PM
Colorado David's Avatar
Default I've got a new noise
2001 Discovery II with about 155,000 miles on the odometer. The engine was replaced by the previous owner with a low miles engine at about 100,000. I have no idea how many miles were on the replacement engine. I have an oil leak that I know I need to work on. I think it's the front cover. I have a complete set of new pulleys, tensioner, and belt that I'll put on when I have it apart. But now I have a new noise. Inside everything sounds normal. When I run the engine with the hood open, it sounds normal. But if I listen by the driver's side wheel well, it sounds like a diesel engine. What could it be? Thanks.
Old Jan 26, 2015 | 03:52 PM
shanechevelle's Avatar
You could have a leaking exhaust manifold on that side.
Where the manifold meets the exhaust pipe, see if you can feel any exhaust leaking out... it can be hot so be careful.
Old Jan 26, 2015 | 10:02 PM
Where the exhaust manifold meets the y-pipe? I'd thought of that. It's quiet when it's cold, but get noticeable as it warms up. I just need the time to work on it. Thanks.
Old Jan 27, 2015 | 08:20 AM
dusty1's Avatar
or where the manifold bolts to the head. I have had those little bolts strip a couple of times
newBrover
Nov 5, 2013 06:59 PM
glassman66
Jul 7, 2012 03:10 PM
Analogkid
Oct 28, 2010 05:38 PM
lipadj46
Sep 12, 2009 07:31 AM
Disco2Fever
Oct 19, 2008 08:05 PM
