Jammed Power Window
My 02 Disco driver side window jammed. It tries to go down, but only in the front. The back of the window will not move. To make things worse, it won't go completely up. There is about an 1/4 inch gap between the window and the frame.
Are there more that one motor in door? Has anyone ever had this happen to them?
There's only 1 motor in the door,
Sounds liketime for a new window regulator..
I had one of the plastic bushing's break.
While I was waiting for the new regulator, I modified a roller from a pocket door hardware (from home depot) to work in the place of the bushing.. Not a permanent fix, but, it worked well until the new regulator came in..
on
Happened to me... i fixed it with plastic roller type thing from my local hardware store..
http://picasaweb.google.com/jycsalas...torFixerUpper#
