Just Completed Plug Wire Change...tips...
Old Apr 24, 2010 | 02:34 PM
IBA 270's Avatar
Default Just Completed Plug Wire Change...tips...
Hey gang...
I just completed my plug/wire change this am. I did TB and induction clean before I started, and I was gigling like a school kid riding around the neighborhood driving that smoke bomb! It ran and idled VERY WELL after the cleaning, but I need the wires after getting misfire codes.
At any rate, there is a good write-up here in the forums on how to complete this. I'll insert a few thoughts on the process...
First, if you're cursed with big hands...it's going to suck for you. It's EXTREMELY tight. The upside is that I'm tall and I can reach...a trade off I guess.
There is one thing that I found that helped immensly; I used a camping pad layed across the radiator/intake manifold. I used that to lay on and get a good angle from the top down. Things went MUCH faster after I did this.
The original wires were pretty brittle and at least two boots were split. Instead of Magnacore, I went with Kingsborne based on some reviews and recommendations. The price is way right, and quality is absolutely high, and the lengths are perfect. Not too long, nor short. They will snap on to the wire seperators, but are a little tight as expected. I went with yellow. Because yellow wires offer less resistance .
For plugs, I went with Bosch +4 Iridiums. Expensive, yes. But that's what they had...
Truck idles unbelievably well!! No hesitation or stumbling. I did have a little of this before...and I'm not sure if my intake and TB cleaning fixed this. That being said, the wires WERE brittle...and boots split. They needed to be changed, for sure!
Dive on in on this project. You WILL cuss a little, but it's straight forward. Take your time, and you'll be fine.
Old Apr 24, 2010 | 04:22 PM
BowRat's Avatar
+1 on the pad to lay across the engine. I have big hands with fat arms and found it pretty challenging, but getting right up there made a world of difference.
CPDieker
Jun 6, 2012 09:36 PM
primey
Oct 26, 2011 07:24 PM
AuZZZie
Jun 9, 2011 11:25 AM
ecugradx2
Aug 7, 2009 07:45 AM
malmberg
Dec 16, 2008 06:37 PM
