Just converted to coil springs..
Old Mar 30, 2007 | 12:33 PM
Tris's Avatar
Default Just converted to coil springs..
.. and now when the truck is off i hear 2 clicks every 20 seconds that sound like they are coming from the compressor (it may happen when its running but i wouldnt be able to hear it). my first thought was to take out the fuse but it happens to be used for ABS too (though it still happens when the auto-leveling/abs fuse is out).
any ideas what this is and if it could cause a problem in the future?
on another note i would like to thank everyone who mentioned Arnott Ind. i am much happier with the coil spring setup
Old Mar 30, 2007 | 01:07 PM
Default RE: Just converted to coil springs..
Did you have your dealer turn off the SLS thru the ECU?
Soory to hear you got rid of that great rear suspension, with all the off roading I do, I wouldn't think of converting.
Mike
Old Mar 30, 2007 | 01:41 PM
Tris's Avatar
No i havent been to the dealer but that makes sense. ill make that happen
Yeah i was a little dubious about switching to springs. However i dont do much off roading and i fogured id try them out for kicks. we'll see how it works out.
thanks for the reply
-Tris
Old Mar 30, 2007 | 03:23 PM
You will need to have some one with a test book or AutoLogaic scanner shut off the SLS function in the ECU to stop the pump and may be turn off any warning lights on your dash.
Mike
Old Mar 30, 2007 | 03:38 PM
jdelp's Avatar
Along the lines of the compressor, I have a question about the suspension in my '04 disco II. I've noticed that on occasion at startup the compressor is on and shuts off as the suspension is "level." Is there an indicator light that that illuminates -or is supposed to - when this is happening? I also wonder if there is a slow airbag leak b/c the compressor seems tocome on more lately...or me being paranoid.
b_woodroaster
Nov 5, 2010 08:54 AM
cpt blakesatan
Aug 17, 2009 07:31 PM
dkinder
Oct 2, 2008 06:43 PM
tee51397
Jun 2, 2008 01:53 PM
