just died
Old Jan 7, 2012 | 08:10 PM
carlos84's Avatar
Default just died
So I went to start the vehicle this morning kinda hesitated to start, 10 min into driving and it just died on me, all spark plug wires look good. the truck turns over but will not start any suggestions as to what the problem is?
Old Jan 7, 2012 | 08:40 PM
Bet you have a bad alternator, that is unable to charge your probably near bad battery, or if the engine turns over at it's regular speed and won't start the the crank sensor may be gone.
Go try to start it tomorrow, if it starts, it is the crank sensor.
If you have any question, since you ar local, send me your number after you try to start it and we can talk.
Old Jan 7, 2012 | 09:03 PM
Like Mike says, sounds like crank position sensor. When it cools off spark returns. You can pour cold water on to cool it off also, it is shown on attached pix, the sensor is bolted to the engine under a little cover (just follow the wire down), driver side rear of engine. If you DIY the replacement, be sure to draw exactly which bolts come from where and where the spacer is. Many have put in a new sensor, still would not start, because spacer was wrong.
File Type: pdf
Old Jan 9, 2012 | 10:11 AM
carlos84's Avatar
Will try tonight Thanx !
Old Jan 10, 2012 | 10:22 PM
carlos84's Avatar
You all are awsome! Have have many little problems with this vehicle due to previous owner and all my problems have been solved through this forum. Thanks disco mike and Savannah . 99% sure it is the crank sensor. thanks !!!
colin2496
Mar 17, 2020 04:54 PM
Jared9220
Jan 22, 2012 09:45 AM
03discoman
Dec 5, 2009 03:42 PM
kayaku
Jan 18, 2009 10:24 AM
rick.miles
Freelander
Nov 27, 2008 03:08 PM
