JUST one amigo HD
Old Oct 21, 2014 | 06:10 PM
mwurster's Avatar
4th Gear
Default JUST one amigo HD
1999 DiscoII. Had 3 amigos, changed shuttle valve. tested all wheel sensors.
Abs and tc lights gone now but, hill descent is still there.
Help.
thanks
Old Oct 22, 2014 | 09:19 AM
drowssap's Avatar
did you replace the o-rings in the shuttle valve when you "changed" the shuttle valve
Old Oct 22, 2014 | 10:06 AM
jafir's Avatar
Is the switch on? ;-)
Old Oct 23, 2014 | 08:13 AM
DustyLBottoms's Avatar
Hill decent only works in low range....?
Old Oct 23, 2014 | 08:22 AM
jafir's Avatar
Yessir
Old Oct 23, 2014 | 10:09 AM
mwurster's Avatar
4th Gear
Any ideas where the most likely places this would occur?
"If DTC P1591 is set, there is a low ABS rough road signal circuit. Signal from SLABS ECU is shorted to ground."
Old Oct 23, 2014 | 03:19 PM
jafir's Avatar
Maybe corrosion inside the ECM
Old Jul 24, 2015 | 11:04 PM
potxoli's Avatar
bump for an old thread. I too have been recently been getting a single amigo with the hill descent simbol turning on. I've never had the 3 amigos. ABS and TC work fine. I tried searching for this, but no definitive answer came up.
I'm thinking a short or sensor issue, but don't know where to start looking.
PS: The Hill Descent button is not pressed. When I press the button a different light lights up on the dash. The one that lights up for me now is in the lower left. In the diagram below, light #27 is the one that is lit, not light #1 which lights up when I press the button
Old Jul 25, 2015 | 08:27 AM
After rebuilding the module, did you actually clear the codes, 1590 and all or is it still on.
Old Jul 25, 2015 | 04:55 PM
potxoli's Avatar
Hi,
I am not the original poster. I never rebuilt the module since I never had the three amigos.
My problem is that the hill control light lights up sporadically. Today it is off. Yesterday it was on. There are no CEL codes thrown.
kallgrer
Jan 14, 2010 08:54 AM
Princess
Jul 4, 2009 12:24 PM
rmally
Apr 22, 2008 12:26 AM
