Just raised 2 inches and put new rims and tires…check it out. Now Light r on!
Old Feb 8, 2022 | 08:38 AM
Stratos993's Avatar
Update! They are off now, but after 20-30 min of driving they pop on. So weird!! Also, my front drivers side light went out....so random.
(Thank you for your insights. (btw I do not have airbags)
Old Feb 8, 2022 | 07:43 PM
Stratos993's Avatar
Good eye! so that is for a bull bar light hook up.
Old Mar 2, 2022 | 01:01 PM
Land Rover Doc's Avatar
What size tires?
Old Mar 2, 2022 | 01:18 PM
Stratos993's Avatar
The light went off on its own. Got lucky! Now I got a chirping sound to deal with….
Old Mar 2, 2022 | 01:59 PM
mollusc's Avatar
Chirping is often reported to be the front driveshaft. Take care of it before it grenades and takes out your transmission!
Old Mar 2, 2022 | 02:29 PM
Stratos993's Avatar
Yes sir! my new propshaft is on the way!..... Question for you. Do I need a prop shaft spacer for my 2 inch lift??
Old Mar 2, 2022 | 02:39 PM
whowa004's Avatar
depends on what shaft you ordered. A GBR or tom woods no. If you bough the cheap one from L8 then either return it and get a woods or GBR or you can try and run it with a spacer I suppose. I don't have any experience with any other driveshafts. But I'd be very wary of the cheap L8 with any amount of lift...
Old Mar 2, 2022 | 02:51 PM
Stratos993's Avatar
No I a high quality prop shaft from a A-1 in Milwaukee.
Old Mar 2, 2022 | 03:09 PM
Dave03S's Avatar
The cheap L8 shaft is OK if you go in knowing you get what you pay for.
I installed one about 5 years ago and just now a U joint is starting to squeak... I suspect it is probably the center ball rather than a U joint as that is the part getting the least lube and right in the hot spot between the cats.
For under $200 I would consider it safe to use if you keep an ear tuned for any squeaks and keep it lubed with every oil change.
I will find out which part failed on Friday.
Old Mar 2, 2022 | 07:50 PM
longtallsally's Avatar
GBR built the shafts in my last Disco. They will be building the ones for my new one as well…
