K & N air filter
Old Dec 6, 2008 | 08:42 PM
pilsner's Avatar
Default K & N air filter
why is it that i should not run K & N air filters in my rover?
Old Dec 6, 2008 | 08:55 PM
Default RE: K & N air filter
Because it will kill your MAF.
K&N air filters use LESS filter element but then coat it with a light oil.
Less filter element lets more air through, better breathing engine more power...in theroy, I do not think this is true on fuel injected engines.
The oil traps the dirt because thedirt sticks to it, the filter must be washed, dried and then re-oiled every 10,000 miles. The extra oil that is on the filter element will drip off and collect inside the MAF and contaminat the sensor inside it.
A new MAF for a DII is around $150.
Old Dec 6, 2008 | 09:49 PM
AK Rover's Avatar
I use a K&N replacement filter in my Dodge and have not noticed any perceptible difference in horsepower. The K&N filtercharger injection performance kits actually make a noticeable difference in power. On my Dodge diesel it also removed all the baffling on the air intake and really made it sound cool when the turbo spooled up.
I think with the low power output from the Rover engine it would notice a power increase from the K&N filter but it's not worth risking destroying the MAF to find out.
Old Dec 6, 2008 | 10:59 PM
phatduc's Avatar
Didn't do anything noticable for power on my DII. The cake of oil and dirt left behind killed the mass airflow sensor though...
________
Hotels in mexico
Old Dec 7, 2008 | 10:37 AM
AK,
Your Dodge doesn't have a Bosch MAF like our Discos, they can't handle the oil contamination.
Old Dec 7, 2008 | 12:25 PM
mh's Avatar
mh
I had a K&N on my Golf TDI, and I kept having to clean the MAF every time I changed the engine oil. I got rid of the K&N and no more problems. The Golf has a Bosch MAF, too I believe.
It is a cheap, half-a**Ed way of doing things, but electicl contact cleaner will clean out a MAF, and the can cost ony $5, vs the $130 for a new one.
So far, no MAF problems on my Disco, but I'm notusing a K&N filter.
Old Dec 7, 2008 | 01:23 PM
04BluDisco's Avatar
Ran into the same issuse with K&N as described with an older BMW. I kept having issues with the air sensor and finally figured out it was the K&N oil. Electrical contact cleaner fixed the issues, but I have steered away from K&N on injected motors since.
fuel
Dec 13, 2004 04:49 PM
