kevman1
Old Dec 10, 2012 | 06:37 PM
kevman1's Avatar
Default kevman1
Please help!!! I am totally locked out of my discoII 03, all doors are locked and will not open with key or FOB. I reached in and pulled the cable for the hood and found out my battery had a dead cell, I have since replaced the battery with a new one, I also replaced the battery in the FOB. still not unlocking the key won't even go all the way in the driver's side door. I don't know what else to do...
Old Dec 11, 2012 | 03:43 AM
black duck's Avatar
4th Gear
Default locked out
if you got the key code numbers you can use them to get in it i think there is an thread about it not sure where as i just have joined forum.the numbers mean how many turns right and left in the drivers side door key hole to unlock system.
hope this helps
Old Dec 11, 2012 | 03:54 AM
hilltoppersx's Avatar
do you normally hit the lock button once or twice?
Old Dec 11, 2012 | 06:46 AM
drowssap's Avatar
it could be in Super lock, i think you have to put the key in and unlock it 4 or 5 times to reset it. i should be in your manual or rave
Old Dec 11, 2012 | 07:24 AM
Do you have any power to the vehicle, like head lights?
Lock and unlock the doors 3 times and also reset the enerita switch and see what happens.
Old Dec 11, 2012 | 09:05 AM
kevman1's Avatar
Default kevman1
Hi DiscoMike,
I cant turn the key on the door, I am not sure what the enerita switch is. I rec'd a call last night from lr2001silver and he said that i wasn't in superlock because I can still arm and disarm the alarm, so he had me check the fuses adn relays under the hood all seem ok except a 40 amp for fan #9 I think. I have a 3" opening (left open) in my dr. side window and have been trying to grab the latch to open twice to trigger lock I can't so I have a second locksmith coming with a slim Jim to try and ope silver told me that this may work since I can disarm and turn of the red LED on dash
Old Dec 11, 2012 | 09:10 AM
Try a stick, thru the window and push the dash button, it's easier.
Old Dec 11, 2012 | 09:23 AM
kevman1's Avatar
Default kevman1
Thanks DiscoMike,
I tried that before with the old battery, maybe it didn't work because the old battery had a bad cell and not enough juice?
Old Dec 11, 2012 | 09:26 AM
Dead cell will do funny things, try with new fully charged battery.
Old Dec 11, 2012 | 09:29 AM
lr2001silver's Avatar
Banned
Okay so I spoke with kevman and its a issue where if he pressed the lock button on the key remote twice his truck arms super lock mode as normal but when he pressed the unlock button his turn signals illuminate as normal and the red led stops rapid "super lock" flash but none of the doors unlock. So the alarm is responding to the remote just the door locks are non responsive. maybe blown fuse not sure but he can not access the passenger fuse panel to check. So since he can essentially turn off the alarm with the remote he should be able to get a hook or wire on the interior door handle and pull open 1 time will mechanically push the lock up then he can access the interior fuse panel and locate problem.
His driver door key access is damaged and he can not get his key in the door lock.
His window was left down a 1/4 of a inch!!
Not sure why the locks stopped responding to the remote but it would seem very rare if they all failed at same time.
