Key Fob question
Old Jul 20, 2020 | 01:31 PM
ReconDoc83's Avatar
Originally Posted by Freeman Decker
1st go to owner's manual & check on the FCC ID you'll want purchase FOBs with this ID # 2nd code right now you'll need help.. on Range Rover the can be synced.. on Disc 2's don't know yet but it's 6 letters & # code buried in the string of letters & numbers on package.. which 6? by trial & error or look for help to identify location in "string sequence"
None of that is true; the 6 digit code is printed on the chip.
Old May 19, 2022 | 02:34 PM
Jamesw1233's Avatar
3rd Gear
Default Key has a 7 digit code
After market key has a 7 digit code, will i still be able to program this into my bcu with a nanocom?
Old May 19, 2022 | 06:28 PM
Extinct's Avatar
Post a pic
Old May 20, 2022 | 02:37 AM
Jamesw1233's Avatar
3rd Gear
It has a 7 digit code then a longer only letters code underneath
Old May 20, 2022 | 07:59 AM
Extinct's Avatar
Did the key come in a bagged package? I usually order mine from remotekey.uk.co and they come in a package with the code the Nanocom uses.
Old May 20, 2022 | 02:31 PM
Jamesw1233's Avatar
3rd Gear
Well it's an old aftermarket key, i figured because i have to for a new bcu then i may aswell get a proper valeo disco key with the 6 digit code, cost me 20 quid just for the chip part though lol
Old May 20, 2022 | 05:28 PM
longtallsally's Avatar
I’m gonna say that one won’t work. My ‘04 came with a “brand new” (which it was) China knock off. Tried with my Nanocom. Nope. I got all the codes and numbers I could from the chip and tried all of them. I posted to failbook groups and just did a bunch of research on it, and it seems the only ones that will work are the OEM ones.
This is what mine looks like:
So I’ve decided to now prioritize when I’ll get keyless entry and pay the ~$300 for a new OEM fob.
Old May 21, 2022 | 12:20 AM
acg's Avatar
acg
Beware of the Ebay ones from China..... some are 433 mhz for Rest Of World..... while some are 315 mhz for the North America Discos.
I was helping a friend find a fob that has the 6-character code that can be programmed with my Nanocom. Here is an interesting one... We came across this seller selling new 315 mhz fobs for less than $30. The pic shows the 6-character code with the date of manufacture. However, the 6-character codes on the factory circuit boards contain a combination of alphabets and numbers. This one on Ebay only shows all numbers. Plus, the date of manufacture shows 2007 (well past the 2004 end of model year).
https://www.ebay.ca/itm/353416235539?fits=Year%3A2004%7CModel%3ADiscovery% 7CMake%3ALand+Rover&hash=item52493fca13:gpYAAOSw Wilhuq1o
Old May 21, 2022 | 04:36 AM
Extinct's Avatar
I can confirm the key fobs from remotekey.uk.co work fine, have purchased several, about $125 US
Old May 21, 2022 | 11:33 AM
Harvlr's Avatar
If you can find an original D2 at a wrecker you can program your BCM to accept it using a Nanocom. Maybe roverguy.com ?
