Key Fob question
Old May 22, 2022 | 12:43 AM
  #21
Discorama's Avatar
Originally Posted by longtallsally
I’m gonna say that one won’t work. My ‘04 came with a “brand new” (which it was) China knock off. Tried with my Nanocom. Nope. I got all the codes and numbers I could from the chip and tried all of them. I posted to failbook groups and just did a bunch of research on it, and it seems the only ones that will work are the OEM ones.
This is what mine looks like:
So I’ve decided to now prioritize when I’ll get keyless entry and pay the ~$300 for a new OEM fob.
These designs simply don't work. I tried a bunch of both, 315MHz and 433MHz (I got a 433MHz receiver for that). The fobs I got transmit at the correct frequency, which can be tested easily with a HAM radio or RTL-SDR. I also checked the output signal of the receiver with a scope. It shows the 0s and 1s coming out every time I press the button on the Fob. The transmitter is working, modulating some codes, the receiver can demodulate the signal but the ECU doesn't accept the code. I tried all possible procedures with my nanocom for hours. Then I got a used OEM fob for $25 and it worked right out of the box.
Old May 22, 2022 | 05:08 PM
  #22
Harvlr's Avatar
The 2 working fobs I have for my D2 are from a wrecker, not from my vehicle or my BCM but a different D2 entirely. The Nanocom synced my BCM to the 2 fobs without a problem.
Old May 27, 2022 | 01:58 PM
  #23
longtallsally's Avatar
To add to the “you need the correct transmitter for this to work” thoughts, I went ahead and ordered a new OEM fob. Took less than 2 minutes to program with the Nanocom. Now I’m on the hunt for a used transmitter as I have a perfect case and brand new key to be cut- just need the transmitter.
Sean Winter
Jul 9, 2020 08:06 PM
ruffram
Jul 9, 2020 10:38 AM
nvrenuf
Sep 23, 2013 08:30 PM
edwhittle
Feb 5, 2013 08:48 AM
aarongregor
Jan 21, 2013 11:39 PM
