Key Fob Question
Old May 1, 2014 | 01:50 PM
parkerlander's Avatar
Default Key Fob Question
99 disco II
part of my restoration efforts. only came with one key fob and it worked for a while. the micro switch(s) is gone from the circuit board for unlock but lock is still there. looks like one option is to get a new fob and have it programmed from the dealer?
I don't care about having the key cut done now but it would be nice to have the key fob for lock /unlock.
guess my question is does the 99 key fob set an immobilizer as well?
any input or info welcome!
Thanks.....
Old May 1, 2014 | 04:05 PM
acg's Avatar
acg
Th cheapest route is to get a used key fob from Paul Grant (he is a popular dismantler on this site). I bought one from him a few months ago for around $40 to $50.
I then used my Nanocom programmer and programmed in the bar code number into the Nanocom. The fob worked instantly.
You can take it to a 3rd party Land Rover shop to get the programming done, that is, assuming they have a programming unit. It is cheaper than taking it to a Land Rover dealer. The programming should not take more than a few minutes.
Another cheaper alternative is to get a replacement microswitch from Ebay. You will have to do some soldering:
Switch Button for Remote Key Fob Land Rover Discovery Freelander | eBay
Old May 2, 2014 | 12:50 AM
jfall's Avatar
take the fob apart carefully.
See if you can inspect the switch.
If you can make it work all apart, then the rubber buttons are worn out and need replaced.
You can buy those on eBay.
Old May 2, 2014 | 12:52 AM
Hey thanks, yea I found and older thread about the micro switch kit and just bought it since I don't have a way to program the key myself. $15 shipped with a new case , key and 4 micros . Worth a shot and don't see why it wouldn't work. I know the current chip works because I can unlock it by slipping a wire across the unlock terminals and the "lock" micro is still very solid and has a good button and works perfectly.
Old May 2, 2014 | 11:21 AM
acg's Avatar
acg
Don't be drinking a beer while you are doing the soldering. You will need steady hands with the tiny weeny micro switches!
Old May 7, 2014 | 12:56 PM
hahaah ok , will post when it arrives from Chinaland......
Discolife
Nov 25, 2011 11:38 AM
pilsner
Apr 7, 2008 03:24 PM
rlp2011
Sep 17, 2007 08:19 PM
semicntrldchaos
Oct 4, 2006 11:26 PM
Jay
Apr 27, 2005 03:49 PM
