Key and Fob Upgrade Pictures
However I would imagine it does not matter how long the battery is removed, if you do remove it for any length of time for some reason. Based solely off of my experience with many other key fobs on other vehicles.
on
I did the same modification and took the key blank out of the fob to have it cut at an Ace Hardware. They cut the key ($2.99) and it opens the door, but won't turn the ignition. Now I have to either find a locksmith who can fix the cut key or get a new one (I already ordered 2 more off eBay in case). So just be wary of where you take it to get cut.
![Name: image13_zps9ec0661f.jpeg
Size: 28.4 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/41080d1501375149-key-fob-upgrade-pictures-image13_zps9ec0661f.jpeg)
![Name: image14_zps18ce566c.jpeg
Size: 44.5 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/41081d1501375149-key-fob-upgrade-pictures-image14_zps18ce566c.jpeg)
![Name: image15_zpsf4681d59.jpeg
Size: 7.0 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/41082d1501375149-key-fob-upgrade-pictures-image15_zpsf4681d59.jpeg)
You have to get the spring in just right to get it to work. It's a little tricky and took me a couple tries before I got it. Basically the spring must be "wound up" before you put the two halves back together.
