Keyfob plip code conversion, short to long
OK. Looking through the PDF document to do the reverse hash generation to get the CODE1 & 2. I think my calculation is off, when i'm doing 5c & 7c in the process. Possibly because math was not my strong suit. but good lord i'm good at following instructions, but i'm not getting the same result. anybody done this before that's still around? I get a division result after 143/43=3.325581395348837. But when i look at the example it's a way different value.
My transmitter code:
2EA7DB
Region -USA = J
Source Document:
https://landroverforums.com/forum/di...ey-fobs-45057/
Note* attached PDF is the same worksheet from the Original linked thread listed above. figured i'd make it easy, instead of jumping around to find the related content.
Note 2*. use the Excel Sheet Sandman614 has below, it does everyhing you need when you drop in your 6digit plip/fob code. Otherwise, if you really want the long division result. below link will get that remainder value.
https://www.omnicalculator.com/math/remainder
2EA7DB
Region -USA = J
Source Document:
Last edited by Seattled2; 12-13-2018 at 05:32 PM. Reason: adding calc for remainder value
2EA7DB
Region -USA = J
Source Document:
2EA7DB
Region -USA = J
Source Document:
Seattled2 (12-13-2018)
Update:
Got it programmed using my friends Diag Tool `Launch x431`. Which researching, is the same company that makes the iLand diag. It looks like the iLand is restricted to just Land Rover, vs having additional manufactures.
BUT that Excel Sheet is perfect! and saving it for the future. It really should be a sticky imo. Thanks again @Sandman614!. I had the reverse code#2 off, and was able to program it.
Note on Keyfob Programmers, it looks like the following will program keyfob/plips without the long Codes, and just needs the 6digits on the Key:
Nanocom
Hawkeye
Launch x431 (I confirmed this last night). Which means it's possible the iLand as well, as its the same parent company.
Nanocom
Hawkeye
A1Premier (11-21-2022)
on
I have and use the Nanocom, and the Hawkeye. The Naonocom Will program NEW and USED key fobs, with NO bar code needed. The Hawkeye will program only NEW key fobs, but WILL NOT program used ones of any kind. I have no knowledge of the Launch x431; have never owned one. . In reality, though, NONE of these truly program the key fobs, they program the vehicle BCU computer to accept the key fob.key fobs, they program the vehicle BCU computer to accept the key fob.
Hawkeye will program the vehicle with used remotes. I’ve done it. What it won’t do is program them with the short code, or at least the version I had wouldn’t. I got the long code from a user here. I even programmed the same remote on both D2 I had in my garage at the same time to see if I could. It worked, but wasn’t very practical.
I just bought a spare fob off ebay, was SUPPOSED to have the 6 digit code sticker as in the 'for sale' image. It has only the bar codes. I was just looking on the net for bar code to 6 digit conversion, but could only find the opposite........
I'm going to try this later today....post 19#
https://www.aulro.com/afvb/discovery...de-help-2.html
This is EXACTLY what happened to me! Same result on Ebay and on Aliexpress. The seller images show the 6 digit code sticker and then it arrives only with the 2 long barcode/numbers. Update from today - we managed to program one of these remotes using a universal OBD II scanner, it accepted the long codes. So at least we have a workaround for now.
I have contacted Nanocom (BlackBox Solutions support) and they havent been much help yet - from their reply: "remove the 1st digit and use the next 6 digits" - they researched it in the online forums. I pushed back and complained that their competitors (Hawkeye...) know how to work with the long codes, and requested they sort it out.
Could you (or anyone else) pls update us if you figure out how to "translate" the long codes into the 6digits which the Nanocom uses?
Thanks
