Keyless Entry Not Working
Old Jan 6, 2013 | 04:47 PM
rlrigsby's Avatar
Default Keyless Entry Not Working
My original key fob for my 2001 Disco II began disintegrating and when the button covers fell out I just started using the key to open the door until I could get a replacement key fob. That was about 9 months ago.
I had just found a new fob housing and when it arrived yesterday, I switched the internal components over to the new housing and in doing so, discovered that the battery was also dead. I replaced the battery and upon trying it, the keyless doesn't work even though the red light indicator on the fob is lit when pressing it.
Is there a fuse for the keyless and if so, where do I locate it? Also, if the battery in the fob dies do I have to have the keyless reprogrammed to the vehicle since so much time has passed?
Thanks for your help.
Russell
Old Jan 6, 2013 | 05:36 PM
You do not need to reprogram the FOB if your battery dies.
When you push the FOB buttons does the little red light come on?
Old Jan 6, 2013 | 09:01 PM
rlrigsby's Avatar
yes, the red light on the fob is active when pressing the button.
Old Jan 6, 2013 | 09:30 PM
bigcraigman's Avatar
Don't know why the fuse would be blown but I blew mine a while back changing an interior light.I think it is fuse 19. It goes with engine immobilization and other components.
ScreamingLife
Apr 10, 2014 07:58 AM
Frank4
Mar 21, 2014 05:21 AM
Doc Stone
Oct 31, 2011 09:01 AM
Brad S1
Sep 2, 2008 11:00 PM
faith2
Sep 14, 2005 03:04 PM
