Knock and grind coming from pulley?
Old Jun 2, 2012 | 08:47 PM
Keecho's Avatar
Default Knock and grind coming from pulley?
There is a new sound coming from i think either my ac compressor pulley or power steering pump pulley. Very annoying but im sure its one of the cause as soon as i spray wd 40 at them, sound goes away but comes back in 15 mins. My other pulleys were replaced lately when i put the motor back in. Im thinking its one of the ones mentioned because they were sitting in a bucket for about a year. Anyone heard this knocking pulley noise?
Thx
Jack.
Old Jun 2, 2012 | 09:00 PM
Take an extra long screw driver, or a broom handle, and hold one end to your ear and place the other on the suspect item. You will hear it much better. Or mechanic stethoscope. Drop off the serpantine belt and turn each by hand checking for roughness.
Old Jun 2, 2012 | 09:11 PM
Remove the belt, spin the pulleys, you will feel the bad one.
Old Jun 2, 2012 | 10:52 PM
Keecho's Avatar
Found it. Its the power steering pulley/ pump. Took the top of fan shroud off and just put a dab/2 drops oil right in the center around base and noise completely goes away. Where is the bearing? Can i press out, press in? Only reason i ask is pump itself is over 200 bucks, just spent 300 on radiator yesterday. :-( but atleast car is up and running again.
Thanks.
rhino_e28
Jul 7, 2010 07:38 PM
timothybryder
Apr 14, 2009 05:12 AM
98discoIN
Apr 7, 2009 10:07 AM
FALLFORWARD
Feb 18, 2009 08:52 AM
sdsilvere38
Sep 1, 2008 12:08 PM
