Knock sensor code PO327
Old Feb 9, 2018 | 12:47 PM
PAPIRRIN's Avatar
8th Gear
Default Knock sensor code PO327
Hey guys,
I know this topic came up a thousand times, but I am having a difficult time pin pointing my problem.
Recently i replaced the head gasket, had a valve job done , etc, when put back together, it started the first time, and has been running fine, however i just happened to hook up an obd reader to my truck and fault code P0327 came up, I clear it and it comes right back, i see everyone talking about checking the cable, etc. I don't know where the sensors are at can some one please tell me their location, I'd really appreciate it.
Thank You
Old Feb 9, 2018 | 12:52 PM
LR03NJ's Avatar
the cable runs between the steering pump. The truck can run without thoses connected but youll see the constant code. It could have been pinched when you mounted the pump. It wont show any SES light just a pending code. If you want to fix it ok if not its ok too. just me, too lazy with that p code. lol
Old Feb 9, 2018 | 07:26 PM
number9's Avatar
Sensors locate each side of engine block near motor mounts and near plane as the block drain plugs. A web search should result in plenty of images.
Old Feb 10, 2018 | 03:42 AM
The Deputy's Avatar
This is what I found on our 03. While removing the heads, I found the drivers side knock sensor wire had been pinched between the P/S pump bracket an engine by previous owner(s).
Brian.
Old Feb 10, 2018 | 04:51 AM
JUKE179r's Avatar
If needed, a new knock sensor for a Disco 2 was almost $40 at Auto Zone.
Old Feb 12, 2018 | 11:41 AM
PAPIRRIN's Avatar
8th Gear
Thanks guys, i'll see my findings...
Old Mar 22, 2018 | 04:40 PM
PAPIRRIN's Avatar
8th Gear
Well guys, replaced the knock sensor, wiped the code, and came right back, what does the other end of the cable connect to??
Old Mar 22, 2018 | 05:04 PM
Saturnine's Avatar
You should be able to follow it to where ever it goes. It has to go through the firewall at some point
right side or left?
Old Mar 23, 2018 | 08:56 AM
LR03NJ's Avatar
Were you able to check if the cable is intact all the way? If it got pinched, its grounded.
Old Mar 23, 2018 | 10:03 AM
Dave03S's Avatar
Also note that it is a shielded coaxial cable which carries a low voltage signal to the computer. That's why it being pinched or gouged is an issue, once the shield is no good, the signal is trash.
This is not the kind of wire you can just re-solder together. I had mine get pinched by the shop mechanic and they were nice enough to pull another one out of an old wire harness they salvaged for just such occasions.
elpapisf
Jan 27, 2013 09:53 PM
nycdisco85
Sep 5, 2011 10:31 AM
targotsi
Feb 18, 2009 05:58 PM
stupid
Nov 23, 2008 01:17 PM
stick
Jan 27, 2008 01:29 PM
