Knock sensor connector repair
Well while I was putting the heat shields back on, I noticed the connectors for the knock sensors were shot. The passenger side has fraying on both wires. The drivers side doesn't show any fraying I can see but I'm sure if I replace one, might as well do both. Anybody know where to get the connectors and leads? The frayed wire is at the connector so I'll need a new connector on the passenger side for sure.
Thanks
jason
Thanks
jason
Its almost like a smaller coaxial cable then split to the sensors below left and right. I think it will throw p0327 but wont trigger the ses light. If you need to get the similar cable, you can go to markertek, its a shielded thin BNC cable. But a regular stranded wire will do like what I did.
Ok BC I saw it was shielded cable and it didn't throw codes before I did the head job but when I was wrapping new loom covers on it, I noticed it and trying to be proactive. My only concern is that it's right at the connector so I'll need to get a new connector. Any ideas where to get them from
OEM & Aftermarket Connectors - Wiring Products
