KNock sensor wire cut
Clint's Garage: How to rewire your knock sensor
so i found that, i'm at work but from scanning through the first bit it may be a start to repairing the coax style lead. i dont care if i have to go over the top and bypass harness and wire direct from the ecm. i just dont know what my options are. i'd rather not have to get a whole harness and i can't imagine that would be the only solution.
i found that, maybe a thought to wire direct from the ecm to the knock sensor posts.
thoughts?
thoughts?
Ok so check it out I fixed it. There were two 22ga leads right at the connector, used two 7/64 female audio disconnects for the sensor post side, made a pig tail, then crimped that guy with butt connectors to the leads that we're left that I cut and stripped back about half an inch max, and then taped that back to the harness to keep it from hanging all over my starter.
Threw in seafoam and this weekend it'll get new plugs in case the imbalance fouled them. But she's running better already and the engine light went off.
Actually that knock sensor cable is shielded coax and a simple butt splice will usually not maintain the shield.
The signal level is low so a proper shield is necessary in that high electrical noise environment.
Splicing coax does not maintain a proper shield. Period.
You really need to replace the whole cable by getting one out of another harness and putting it back into yours.
Otherwise electrical signals inside the engine compartment will be induced into the system that controls your engine timing. Not a good thing. Splicing does not maintain the shield in coaxial cable.
