Knocking noise
#21
The rocker arm shaft is solid. For that to break-
I am thinking that the head must have been done or==
The mechanic - in trying to stop the tap or knock sound put a shim
under the rocker shaft on one and and not the other - and that snapped it.
A shim on one end and not on the other would stress the shaft.
#22
#25
I assumed it was solid - except for bolt holes and for oil holes from top to bottom.
That's what I get for assuming. The first three letters of assume.
Mine felt heavy when I was replacing them on the D2. Guess those rocker arms
have some weight..
Still ---- For one to crack in half? Seems there needs to be a bending force on it.
Surprised the shaft is then that brittle.
As I understand it - adding heat to steel in the manufacturing process can make it
tempered and harder but more brittle also?
have some weight..
apancho
01-22-2007 12:47 PM
tobob1
11-27-2006 02:11 AM
