Knocking noise
Old Oct 28, 2012 | 01:39 AM
  #21
jfall's Avatar
The rocker arm shaft is solid. For that to break-
I am thinking that the head must have been done or==
The mechanic - in trying to stop the tap or knock sound put a shim
under the rocker shaft on one and and not the other - and that snapped it.
A shim on one end and not on the other would stress the shaft.
Old Oct 28, 2012 | 09:58 AM
  #22
Racer X's Avatar
Rocker arm shaft is hollow.
Old Oct 28, 2012 | 10:53 AM
  #23
lr2001silver's Avatar
Banned
Would never give that shop any more business. They do not seem very educated on rover or determined to please there customer.
Old Oct 28, 2012 | 12:00 PM
  #24
RE: Rocker arm shaft is hollow.
Pix of same
Old Oct 28, 2012 | 03:55 PM
  #25
jfall's Avatar
I assumed it was solid - except for bolt holes and for oil holes from top to bottom.
That's what I get for assuming. The first three letters of assume.
Mine felt heavy when I was replacing them on the D2. Guess those rocker arms
have some weight..
Still ---- For one to crack in half? Seems there needs to be a bending force on it.
Surprised the shaft is then that brittle.
As I understand it - adding heat to steel in the manufacturing process can make it
tempered and harder but more brittle also?
apancho
Jan 22, 2007 12:47 PM
tobob1
Nov 27, 2006 02:11 AM
mr.47
Sep 25, 2006 09:01 PM
tobob1
Sep 11, 2006 09:14 AM
disco1
Mar 3, 2006 10:29 AM
