Land Rover Died This Morning!!!
Old Jan 29, 2009 | 05:06 PM
unimoged's Avatar
Default RE: Land Rover Died This Morning!!!
Technically speaking, there is nothing that you could have done to cause a collision between the valves and the pistons. Not on a pushrod engine with a rev limiter. The only ways for this scenario to manifest itself:
[ul][*]Timing chain failure.[*]Camshaft / crankshaft timing chain sprockets failure[*]Camshaft fracture.[*]Numerous valve springs, retention keys or valve stem failure at once.[/ul]You could not have caused anyone of these failure conditions to happen. I have seen this problem on pushrod V8 engines with 240 K Miles but not on the 4.6 L with 44 K Miles.
I am glad you are getting a new engine from LR, you deserve it, irregardless of this internal engine mechanical failure.
They can easily check by removing the valve covers / timing chain cover / compression check.
Keep us posted, very interesting...
Old Jan 29, 2009 | 06:12 PM
IMurray21's Avatar
I guess the valves were bent.
the other option if it is covered is for them to put in a used engine
Old Jan 29, 2009 | 06:23 PM
DO NOT let them put in a used engine, if they try throw a tempter tantrum like a 2 year old.
YOU paid for the warrenty, its not your fault they are going to loose their A$$'s on this.
martni33
Jun 20, 2011 09:28 AM
avirotwild
Jul 6, 2007 09:36 AM
fazooley
Mar 29, 2006 01:28 AM
disco12
Feb 19, 2006 03:24 AM
skipdow
Jan 10, 2006 07:27 PM
