LAND ROVER DISCO II PROBLEMS
Old Dec 8, 2007 | 05:50 PM
RYANHASADD's Avatar
6th Gear
Default LAND ROVER DISCO II PROBLEMS
Hey, I am new to the forum. I need to remove the plenum to change my spark plug wires. Anybody know where i can get a write up for removla and installation. Thanks...RYAN
Old Dec 8, 2007 | 05:59 PM
RYANHASADD's Avatar
6th Gear
Default RE: LAND ROVER DISCO II PROBLEMS
It's a 99 disocery II Sorry i forgot the year.
Old Dec 8, 2007 | 06:06 PM
willstevens's Avatar
a Rave cd will give you the info you need. I have read in this forum that you can get it online and download it.
Old Dec 10, 2007 | 10:36 AM
tailchaser0527's Avatar
Rave CD is good, and FREE. You can get the plug wires changed w/o removing the plenum, very carefully and with a small set of hands. ( I used my 16yr old brother to help)
Old Dec 10, 2007 | 03:23 PM
Savannah's Avatar
Like you said,small hands does the trick.Also helps if the engine is cold.
Regards
Marius
Old Dec 10, 2007 | 04:17 PM
A 99 D2 can be done by hand without removing the intake, may bruse a knuckle but can be done in under 1.5 hours. What brand of wires are you planning on using??? Magnacor 8 mm are the only way to go.
Mike
Old Dec 10, 2007 | 07:24 PM
SpeedAgent's Avatar
This was posted a while back. I haven't done it myself so I can't verify, but it looks pretty detailed.
https://landroverforums.com/m_41479/tm.htm
Old Dec 11, 2007 | 04:39 AM
jleblanc's Avatar
4th Gear
I used that guide to do mine without removing the plenum, it's very good. I didn't need a special tool to remove the wires at the coil packs though, I could get to them with my hands.
marrtial
Feb 9, 2013 08:17 AM
eyebag
Jul 23, 2010 02:09 AM
sloppyjoe
Oct 11, 2009 10:43 PM
Mountainman
Defender
Jan 13, 2007 06:11 AM
