Land Rover Problems - Please HELP?
Old Jan 18, 2012 | 08:58 PM
If engine will not turn over, take each sparkplug out and inspect for water in cylinder. You could have a cylinder full of water (hydrolocked) - possible cause head gasket failure. Of course, engine could also be jammed because of a frozen starter, but that is not very common. And it could be jammed because it is siezed (oil failure at critical points) [all too common]. Should be able to turn with breaker bar on crank pulley bolt with plugs out. Go ahead and drop belt off at this point for testing.
Old Jan 19, 2012 | 06:02 AM
mrvnduarte's Avatar
5th Gear
Originally Posted by 94svt50
Can you turn it over by hand with a breaker bar and socket on the crank pulley bolt?
Nope!
I had a mechanic look at it he said its the oil pump that needs to be replaced, we will see if it starts after that or not.
Old Jan 19, 2012 | 06:28 AM
94svt50's Avatar
The problem is if the engine is seized because of oil pump failure, then there is no point in putting on another pump. I can't imagine any situation where the broken gears in the pump could keep the engine from turning, unless the engine seized up because of the lack of oil flow. You could pull the timing cover off with the pump in it and then try to rotate engine but, I would be shopping around for a new engine. There have been cases were the gears in the pump have bound up enough to blow out through the front cover but, if that kind of binding had taken place I would think thats what you would be seeing.
Old Jan 19, 2012 | 06:58 AM
Here's a pix of a cracked oil pump. Even when broken, they still rotate, can make a ticking noise, and produce enough oil pressure to turn off the oil warning light (about 7 PSI). Problem is that they don't make enough pressure to operate engine correctly, which is 50 PSI at 2000 rpm when engine is warm.
Oil pump is pretty tough, compared to bearings that are starved for oil.
Please post pictures if you can of your pump pieces the mechanic finds. If oil pump failed, and vehicle continued to be driven, pirece by piece repairs to engine are going to exceed price of a used or rebuilt engine in many cases.
ahurst
Dec 3, 2008 08:07 PM
cohenabigail
Jul 27, 2007 08:00 PM
Mountainman
Defender
Jan 13, 2007 06:11 AM
CJsRover137
Apr 7, 2006 06:46 PM
