Larger alternator..need BIGGER than the RR
Old Sep 17, 2022 | 08:01 AM
The_OGCJR's Avatar
Originally Posted by Mntnceguy
I was under the impression that the P38 alternator is only 150 amp. Did they make a 180 as well? Also, don't the high amp alternators put out like half of their rated amperage at idle? Seems like that may be something to consider as well when going with a really high output unit.
sorry, I meant 150
Old Sep 17, 2022 | 08:05 AM
The_OGCJR's Avatar
Originally Posted by Discorama
Winches draw up to 500amps. It makes sense the support the battery with a higher powered alternator. In addition it reduces the recharge time of the battery. Some run compressors, electric water heaters and have dual-battery setups, which can push a stock alternator over its limits.
yes.
my car audio is at 2000 watts and, I’ve got a winch and I will be running compressor, fridge, dual battery etc.
Old Sep 17, 2022 | 11:47 AM
NVDiscovery's Avatar
Thanks for the detailed explanation. I'll get the RR 150 amp alternator when I'm ready.
Old Sep 19, 2022 | 02:35 PM
ahab's Avatar
Regarding upgrading the factory wiring, my understanding is that the alternator would have to ability to provide more amperage than what the factory shipped with the truck, but that this fact alone wouldn't have an adverse effect on existing equipment. IE, you wouldn't need a different battery, or multiples even, to handle the additional amperage. The existing electronics would still draw the same amperage regardless of what the alternator is capable of pushing out. Anything additional requiring high amperage should have wiring designed for the job and not use factory wiring. I'm not an EE however.
Luckily we still have an actual alternator shop not too far away. I'm going to bring them a worn one and ask them if they can do anything with it.
Old Oct 29, 2022 | 04:20 PM
Does anyone have experience with the Denso remanufactured alternators? Or what brand seems to be the "best" based upon real world experience.
Old Oct 30, 2022 | 09:57 AM
Sandman614's Avatar
I put one on my Tacoma, it charges.
flybd5
LR2
Jul 30, 2022 10:29 PM
SeaRover
Range Rover L322 (3rd Gen)
Jan 16, 2022 07:54 PM
LR03NJ
Jan 10, 2017 08:14 AM
ccraft18
May 12, 2016 06:02 AM
Bajapower
Jan 12, 2011 04:57 PM
