!! Last Chance for 03 D2 HSE7 with Low Oil Pressure on Cold Starts!!
Still think 2-3 seconds is normal. Not a vehicle on earth can get instant oil pressure to everything in 2-3 seconds.
Engines are constantly wearing down bit by bit. Thats why cold starts are probably the most damaging time to an engine honestly. All the oil is in the bottom end/sump, and until it pumps up to the top there is going to be a short time where the engine sounds loud until the oil reaches the moving parts. Hot starts = engine has oil freshly coating everything so zero noise.
Sixpack577 (11-21-2019)
How careful with the rockers were you when you did the hg? Two possiblities:
1. You forgot o tighten the rocker bolts fully (I did this once -bled excessive oil out of the bottome of the towers.
2. You mixed it up and the rocker shafts are upside dine, oil hole on top. That will be low oil pressure.
The oil hole in the rocker shaft is supposed to face down, if the all the rockers or all the mounting post somehow spin 180 it is technically feasible if not likely. I actually left the bolts loose once, had low oil pressure until I pulled the valve covers and tightened them.
