!! Last Chance for 03 D2 HSE7 with Low Oil Pressure on Cold Starts!!
Old Nov 21, 2019 | 07:34 PM
Best4x4's Avatar
Still think 2-3 seconds is normal. Not a vehicle on earth can get instant oil pressure to everything in 2-3 seconds.
Engines are constantly wearing down bit by bit. Thats why cold starts are probably the most damaging time to an engine honestly. All the oil is in the bottom end/sump, and until it pumps up to the top there is going to be a short time where the engine sounds loud until the oil reaches the moving parts. Hot starts = engine has oil freshly coating everything so zero noise.
Old Nov 24, 2019 | 03:30 PM
RossN99's Avatar
Originally Posted by Extinct
How careful with the rockers were you when you did the hg? Two possiblities:
1. You forgot o tighten the rocker bolts fully (I did this once -bled excessive oil out of the bottome of the towers.
2. You mixed it up and the rocker shafts are upside dine, oil hole on top. That will be low oil pressure.
I've done 3 headgasket jobs now and I know they are tight but I was rushing to put it back together so that is a possibility I guess. In what way would they be upside down though? Just thinking off the top of my head I can't think of it mattering the direction as long as the push rods are aligned with the rockers? I didn't disassemble the rocker shafts, just removed and reinstalled.
Old Nov 24, 2019 | 05:09 PM
Extinct's Avatar
The oil hole in the rocker shaft is supposed to face down, if the all the rockers or all the mounting post somehow spin 180 it is technically feasible if not likely. I actually left the bolts loose once, had low oil pressure until I pulled the valve covers and tightened them.
Old Nov 24, 2019 | 08:46 PM
RossN99's Avatar
gotcha. I’ll be pulling it apart soon so let’s check. Good idea though. Thanks.
steveo2000
Oct 30, 2024 08:31 AM
aemnky606
Feb 5, 2016 07:09 PM
Thatguy
Nov 18, 2015 05:11 PM
Dan87GT
Dec 24, 2010 09:48 AM
Cessna310Guy
Dec 7, 2008 02:38 PM
