Lava lamp mirror help
Old Jan 22, 2023 | 07:04 AM
Dave18102's Avatar
5th Gear
Default Lava lamp mirror help
Having fun with my newly acquired 99 D2. First the CPS now a broken rear view mirror that looks like a lava lamp. Saw the defective Donaldson mirror issues. Looking to swap out but trying to stay away from the same junkyard lava mirror. Any aftermarket mirrors out there that don’t require major surgery to install?
also - remove your mirror immediately if it looks like a broken lava lamp. Fluid did quite a bit of interior staining when some of it leaked out.
Old Jan 22, 2023 | 08:33 AM
Best4x4's Avatar
03-04 Rear view Mirrors are excellent
Old Jan 22, 2023 | 11:28 AM
JohnZo's Avatar
There is an online outfit in Texas that will replace the mirror glass for not much $. I am happy with the results after 1 1/2 years. Previous attempted fix with used mirror resulted in more lava.
Old Jan 22, 2023 | 12:17 PM
acg's Avatar
acg
I was not aware there are differences between the pre-facelift and facelifted Disco. I searched and can't find any info on this. What are some of the key differences?
Old Jan 22, 2023 | 08:23 PM
Best4x4's Avatar
The 99 D2 basically had the rearview out of a D1. Map Lights, no compass, and it leaked... D2 from 01 I think switched to the newer style with a compass, no map lights, and with or without HomeLink.
Old Jan 23, 2023 | 06:27 AM
Dave18102's Avatar
5th Gear
Is it safe to assume that the 01 and up models do not have the fluid in them that eventually fails?
Old Jan 23, 2023 | 08:45 AM
greisinb's Avatar
Had the same issue with the mirror out of my '99. Honestly- the best solution for me was to go to the wrecking yard and pull one (literally). You have to connect the wires back up, but you're going to have to do that anyway.
houm_wa
Sep 27, 2022 01:55 PM
volture
Oct 1, 2013 10:03 PM
LL2Juan
Mar 14, 2010 02:48 PM
DesmondMWalsh
Sep 29, 2009 09:25 PM
goldfishy
Jan 20, 2008 03:19 PM
