Leak around rear wheel.
Old Mar 13, 2019 | 03:49 PM
  #31
The Deputy's Avatar
Use the sensor that comes with the new hub, they can vary in length. Also, as l mentioned before...clean that vent tube...if it is plugged...you will continue to have problems. The axle has a vent for a reason, same as your engine (though, it's a PCV), trans, trasfer case, to relieve pressure. The tube just slides out when you depress the collar of the fitting, nothing to do with the fitting (as far as cleaning or removing), the tube just slides through it.
Brian.
Old Mar 13, 2019 | 05:24 PM
  #32
Daytoman's Avatar
Do I need to put this STC 50554 sealant around the drive shaft as pictured? Or do I grease it up real good?
Old Mar 13, 2019 | 09:47 PM
  #33
Daytoman's Avatar
Ok I got it done this evening. Next up, gear oil change. Any particular brand I should lean towards?
I also have one more novice question on this hub change. Once I got the hub bolt tightened all the way down. The drive shaft would slide back and forth a bit. Is that normal?
On the breather tube, how far up does that thing go? I thought it was only supposed to go to the top of the drivers side rear wheel well? I traced mine up to the frame, all the way back to the back of the rig and then waaay up the rear corner. So far I couldn’t see where it ended. It’s got one in line connection to get the extra length of tubing. I guess one of the POs put a wading kit on it? I cleaned up around the fitting and the tube and pulled the tube out of the fitting. I was able to blow air throw it. It wasn’t like blowing through a straw but air was moving....good enough or should I get more flow?
i really appreciate everyone’s help on this.
Old Mar 14, 2019 | 07:30 AM
  #34
Red5's Avatar
I used SuperTech from W-M. No issues, but there are many other opinions.
You mean once you put 360 ft/lbs (or something close) on the axle nut, the shaft would slide in and out of the bearing a bit? No, that doesn't sound right.
My rear breather goes all the way up and ends at the dipstick looking curl just behind the D side brake light assembly.
Old Mar 14, 2019 | 09:48 AM
  #35
Motorhead1's Avatar
You can use any standard 85/140 gear oil, doesn't need to be expensive. My rear breather tube ends with a curly bent end inside the top of the drivers side wheel well, I wish it went clear to the tail light, that's a good thing. Your rear sunroof drains are behind the tail lights also, if you ever have the light assembly out, it's a good time to check the end of the drain to make sure it's not clogged, just an FYI.
Old Mar 14, 2019 | 11:32 AM
  #36
Daytoman's Avatar
No, no....this is once I tightened up the 4 bolts that attach the hub to the axle...it moved back and forth BEFORE I winched up the axle nut.
CATTIVA73
Mar 31, 2015 07:43 AM
robgusto
Jan 19, 2014 10:27 PM
Disco Sam
Sep 2, 2011 05:37 AM
joatman
Aug 24, 2010 11:36 AM
lowerrb
Mar 30, 2009 06:58 PM
