Leak from axle near tire?
Old Nov 20, 2009 | 12:05 AM
jasons's Avatar
Default Leak from axle near tire?
I have a leak at the inside front driver side tire. I dont think its from the brake caliber. What parts do I need to go in and replace any seals that need to be replaced? Is this a difficult job or should I seek out a mechanic?
Thanks,
Jason
Old Nov 20, 2009 | 08:13 AM
jycsalas's Avatar
You may have a leaking hub. Either it is the Hub O ring or the hub itself.
Hub O Ring - http://www.roverparts.com/Parts/FTC4919G.cfm
Rear Hub - http://www.roverparts.com/Parts/TAY100050.cfm
Verify that it is gear oil and not brake fluid. Take the wheel off and clean the brakes with brake parts cleaner.
I had a leaking rear hub and I used White Shepherd stop leak and that with a new O ring fixed it.
Old Nov 20, 2009 | 11:07 AM
What sort of fluid is actually leaking, brake fluid or a heavy colored gear grease?
Old Nov 20, 2009 | 06:26 PM
jasons's Avatar
Its more of a grease/gear oil rather than brake fluid.
Jason
Old Nov 20, 2009 | 06:33 PM
lipadj46's Avatar
Take care of that or it will ruin your brake pads and make a huge mess. Also your gear oil level will drop and will cause premature wear in your front differential.
Note that there is no o'ring for the front hub, that is in the rear. The front axel has an oil seal you need to replace. You need to take off your rotors, remove the 4 hub bolts, and pull the entire hub assembly with axel attached. You can then change the oil seal.
http://www.roverparts.com/Parts/FTC4822.cfm
Old Nov 20, 2009 | 09:05 PM
jasons's Avatar
Lipadj46, the part you listed is for a D2. I have a 96. Is it the same part? Whats the chance that I have a leak from the swivel ball? How can you tell if its leaking? Should I order a seal for the swivel ball just in case?
Jason
Old Nov 21, 2009 | 06:28 AM
lipadj46's Avatar
Gear oil has a distinct smell. Does it smell like gear oil? Yes it could be from the swivel ball also.
Not the same part for a DII. I'm just guessing here that you need to just rebuild your wheel bearings:
http://www.roverparts.com/Parts/9002D.cfm
Put your vehicle in you signature so we can help you better.
post42
Sep 12, 2013 03:57 PM
cationmoted
Oct 19, 2012 07:39 AM
GODSDOZER
Sep 6, 2009 11:44 AM
old gold
Aug 10, 2008 07:41 AM
Art Vandelay
Freelander
Feb 23, 2008 04:26 PM
