Leak down test.
Old Oct 24, 2025 | 09:18 AM
  #21
slvrdisco01's Avatar
Originally Posted by redrover75
I would suggest getting the OEM fuel injectors cleaned and tested. I bought new ones, non oem and a few did not work at all, so I have mixed bag.
Also mineral sprits does a fantastic job cleaning cylinders.
I was thinking the same. I have seen a set of OEM injectors cleaned and tested for around $180. I'll ask at the machine shop if there's anyone local that can do it. If not I may buy them.
Cheers John.
Old Oct 25, 2025 | 12:33 AM
  #22
JohnZo's Avatar
Be careful buying used injectors online. I have been burned before, and also have had very good results. Check out the seller and reviews at least. Mostly "tested" means they simply measured coil resistance, sometimes it means they applied some voltage and heard a click, sometimes it means they were actually flow tested. Sometimes "cleaned" means they hosed them off. Sometimes "rebuilt" means they replaced the little inlet screens. Check them out well before installation, visual inspection, apply a 9V battery and listen for the click, if no click then don't install it.
think the original suggestion was to send your own injectors to a shop specializing in injector testing for less money. That will probably be more reliable than buying a set with unknown origins.
Old Oct 29, 2025 | 12:44 AM
  #23
Thanks guys.
I agree. Buying from a seller and not being 100% sure is not what I want to do. I have an injector testing and cleaning set up coming. I prefer to do things myself. It'll be nice to have for future maintenance. I removed all valves and lapped them in. Guides are in great shape and I have new stem seals coming. Should be able to start rebuilding when the parts get here. Not sure if I already mentioned it. I checked the block for flatness and it's perfect.
Cheers John
1986RRC
Range Rover Classic (1st Gen)
May 16, 2024 10:39 PM
Tommyblack97
Feb 20, 2021 10:48 AM
Disco Mike
Freelander
Oct 11, 2012 02:39 PM
davidlafrance
Aug 31, 2010 05:03 PM
arianamini
May 1, 2007 02:06 PM
