Is this a leak in this picture?
Old Dec 31, 2011 | 10:40 AM
94svt50's Avatar
Default Is this a leak in this picture?
Im in the middle of a water pump/oil pump/ power steering leak fix and I noticed this area on both front corners of intake manifold. It is the consistency of chewing gum and I was wondering if it is a coolant leak or if its some kind of gasket material from a headgasket job last feb. Is this a problem? I dont see any coolant just this gummy stuff that is close to coolant color. Please help.
Thanks
Old Dec 31, 2011 | 10:53 AM
IMHO that would be sealant for the corner notches of the valley pan gasket, had to be done when replacing after the head gaskets. Shop practice from RAVE attached. Of course, you would not want a continuing leak there of oil or coolant.
File Type: pdf
Old Dec 31, 2011 | 11:04 AM
94svt50's Avatar
It's thick like gum. You can scrape it off on your finger nail and it sticks. I have never seen coolant do this before, but I have no experience with dexcool
Old Dec 31, 2011 | 11:18 AM
jafir's Avatar
I have a gooey blob of dexcool under my throttle body heater, and I don't even use dexcool. Mine must have been there from long ago.
Old Dec 31, 2011 | 11:25 AM
94svt50's Avatar
I talked to the guy who did my headgaskets and he thinks it's normal. They use some kind of gasket goo in that corner and he said that oozes out with a few drops of coolant and makes what I'm seeing.
Old Dec 31, 2011 | 12:54 PM
SolbergFanBoi's Avatar
This is of course is best case scenario as it would be an easy fix. Worst case scenario, external head gasket leak but usually will puke oil before coolant on the corners.
It looks like Dexcool to me too...
rgrizzard
Mar 6, 2008 10:16 AM
lightfootboyd
Apr 27, 2007 02:41 AM
Mountainman
Defender
Apr 16, 2007 10:19 AM
The Capstone
May 11, 2006 12:57 AM
disco12
Off Topic
Feb 28, 2006 12:15 AM
