Leaking ACE fluid on Right Rear Arm - How to fix?
Old Dec 16, 2021 | 05:35 PM
flyingmada's Avatar
Default Leaking ACE fluid on Right Rear Arm - How to fix?
Just recently I noticed a significant ACE fluid leak that results in the red beeping ACE alarm.
Other than my current coolant leak issue, the only other spot I could find was on the right rear - below what I think is the ACE arm. That whole assembly seemed damp with fluid as well. Assuming this is the source, how do I fix it? Is there a common failure here? Should I just replace the whole arm/actuator?
Old Dec 16, 2021 | 11:10 PM
disco96sd's Avatar
i would recommend an orthopedic surgeon
Old Dec 18, 2021 | 10:18 AM
frostythor's Avatar
it could just need a 2 new doughty hydraulic washers , but if the ram seals gone a new ram, either way it needs taking out and looking at
Old Dec 22, 2021 | 03:43 PM
suprlite's Avatar
8th Gear
Try tightening the nuts on the cylinder. If that doesnt help, you might have to get new hydraulic hoses.. I got a new one pressed at a hydraulic workshop, for a fraction of the cost of the original ones.
Old Dec 30, 2021 | 09:50 PM
nashvegas's Avatar
I'd say new ACE ram. I thought it might be the pipes or connections, but it was the Ram and I had a very similar fluid leak pattern under my 00 D2.
Old Nov 26, 2022 | 12:32 PM
carlos1551's Avatar
posted into wrong thread - deleted
difrentbob
Apr 12, 2016 03:32 PM
jclrd01
Jan 31, 2014 01:46 PM
ChanchoVerde
Apr 12, 2010 10:00 AM
humroot
Mar 27, 2008 01:24 PM
POPPY1
Oct 28, 2007 11:38 AM
