Leaking radiator
Old Jun 5, 2020 | 02:55 PM
dgm's Avatar
dgm
Default Leaking radiator
Now that I got the car unlocked the reason why the battery went dead is I had a leaking radiator and wasn’t driving it. Let it rain and heat up for a few minutes and this is what I found.
The screw was rusted although intact. Not sure if it’s perforated the radiator or not the other side look fine
Old Jun 5, 2020 | 03:21 PM
merebel's Avatar
Typical spot to leak as they crack from the screw over time.
new radiator time
Old Jun 5, 2020 | 03:48 PM
redwhitekat's Avatar
Cheap eBay rads have a good rep around here super cheap.
Just remember when putting that screw back in cut a bit of the tip so it’s not that long
Old Jun 5, 2020 | 08:32 PM
Extinct's Avatar
This!
Old Jun 5, 2020 | 08:52 PM
Best4x4's Avatar
Yep cut off like 1/8 of an inch & never have that problem again.
Old Jun 5, 2020 | 10:49 PM
Dave03S's Avatar
As long as you remember to put that same short screw back in the same hole the next time...
Old Jun 5, 2020 | 11:18 PM
dgm's Avatar
dgm
Default Any advice on replacement radiators.
Wanted to see if anybody had any thoughts specifically on radiators and while I’m doing the radiator should I replace anything else?
Old Jun 6, 2020 | 05:23 AM
Extinct's Avatar
If you haven't already done it I would do every hose, the bottle, and the water pump.
Old Jun 6, 2020 | 07:24 AM
The Deputy's Avatar
I usually add a couple flat washers to those screws, helps add a bit of stability to the shroud cover also.
Old Jun 6, 2020 | 02:32 PM
dgm's Avatar
dgm
Default Now which e bay radiator to get
piperff
Jul 7, 2019 10:56 PM
mxexux
Nov 26, 2018 10:21 AM
dparham
Apr 2, 2013 11:39 AM
Spike555
May 30, 2011 02:53 PM
dc10freighter
Aug 19, 2007 10:14 PM
